Brief Description: Wing to body fairings primed...
Today I primed the wing to body fairings, the HS to body fairings, the aft fuselage access panels and the cowling exit air support bracket panel. Then I sanded the main gear leg upper intersection fairings after the micro application.
Wing to body fairings, aft fuselage access panel and cowling exit air support bracket panel primed
HS to body fairings primed
Main gear leg upper intersection fairings sanded after micro application
